Mikal_Man
Sep 02, 2022Follower
My Netgear AX1600 Mesh Extended will not accept my router's password
Hello, I have a Netgear Wifi Extender, and I am trying to set it up in the Nighthawk app. I get through most of the setup process, and am now brickwalled at the part where I connect my Router to the Extender. I have selected both the correct 2.4 & 5G networks. When asking for my password, I type it in EXACTLY as it is printed on the bottom of my router (we have not bothered to change the default Network name/password). I type in the password, and hit next, and the app says "Verifying and Connecting". The circle spins for about 10 seconds, and then proceeds to tell me that the password is incorrect. I have verified several times that it is typed exactly as it is printed on the bottom of my router, and I have tried it with both caps & lowercase, to no avail. This is extremely frustrating, and would love some help and a possible resolution lol. Thank you for your time
1 Reply
1. what router do you have? (model)
2. what extender do you have? (hint, ax1600-/1800 is a speed, not a model)
3. Try going into your router and changing its ssid. Some devices struggle with special characters/spaces. So try changing the ssid/password
