aarushing
Mar 02, 2024Follower
My Netgear EX6400 won’t stay connected
I purchased the range extender and set it up using the Nighthawk app. It worked the first night and I haven’t been able to get it to stay connected since. I have done a factory rest, reset my router, gone through all the normal troubleshooting and I still can’t get it to work. The power light is solid green so is the WPA and the client. The router light is red. When I try to rerun the setup wizard it says it can not detect network NETGEAR_EXT. I have shut off anything that would interfere, security (VPN, etc), as well as cellular data so only WiFi is connected. Any advice would be appreciated!
No RepliesBe the first to reply
