onkey89
Apr 03, 2022Follower
My Netgear nighthawk x4 wifi range extender is becoming weaker
4 months ago I have purchased a wifi range extender Netgear Nighthawk x4 dual band. I have plugged my pc ethernet cable directly into the extender. My internet speed at my router is always 100mbps an...
Apr 03, 2022Guru - Experienced User
You're checking the speed on the pc hardwired into the extender?
Have you tried changing the channel the router is broadcasting on?
Do you have a screen snip of the extenders status page?
