Retired_Member
Nov 18, 2019My Netgear Wifi Range Extender won't connect to my Roku.
So to make this short and sweat for now my Roku will not connect to my Wifi range extender. It will connect to the main netgear router signal but not the extender which the same connection just exten...
Nov 18, 2019Guru - Experienced User
Is the roku able to see the extender's wifi?
If everything else is working, i'd be better on either the roku being wonky or the roku's connection not recognizing something in the password/ssid.
A couple things i'd try first.
1. Just for testing purposes, disable wifi security. See if the roku can connect on an open wifi to the extender.
2. Try changing the wifi password. avoid special characters/capital letters for the time being.
3. Try changing wifi channels.
