Chloi28
Apr 10, 2020Aspirant
My range extender ex2700 won’t take my WiFi password
I can get though the steps but when I try to connect it says my usual password is wrong but it’s not!! Help!!
Chloi28
Apr 11, 2020Aspirant
Set it up via wps yes
Not sure about the firmware it’s just brand new
Wireless router
Thanks for your help!!
Wireless router
Apr 11, 2020Guru - Experienced User
Chloi28 wrote:
Set it up via wps yes-----Try using the installation wizard and not wps. wps isn't coded the same between all manufacturers.
Not sure about the firmware it’s just brand new--------then it might need to be updated. You can see what firmware you're on when you log into the extender. The firmware can be downloaded from the support site. go to netgear.com/support/ and type in the model. It'll bring you to the manual, firmware, and the install guide for the installation wizard.
Wireless router------not even slightly helpful. What brand and model? not all models work well with extenders.
