glotzy
Jul 03, 2022Aspirant
My Rextender (AX1800) is working, but app can't find the router?
Weirdly I've managed to set the extender (AX1800 4-stream WiFi Mesh Extender) up, its all lit up in green and has done the trick to boost the WIFI in the downstairs area of my home. Problem now is th...
Jul 03, 2022Guru - Experienced User
Make sure on the phone that private mac/ip address is disabled. Also make sure icloud relay is disabled.
glotzy
Jul 04, 2022Aspirant
Thanks and have done both and still same issue!
- plemansJul 04, 2022Guru - Experienced User
did you try factory resetting the extender and setting it up using the installation assistant?
Are you able to access it using its ip address (found in your router's attached devices list)
