Tricia0915
Jul 05, 2020Follower
My WPS won't light/connect so I have no WiFi security on router?
I was able to set up the extender by the website with the exception of the WPS. The light blinks for about 30 second or so then shuts off. I tried to reset and connect via WPS button on my router, ...
DexterJB
Jul 09, 2020NETGEAR Moderator
Hi Tricia0915, when pressed, the WPS light will only light up for about 2 minutes before it goes out again. This the time window to allow you to press the WPS button on the device that you are looking to connect.
Dexter
