Timothyah2
Sep 29, 2022Guide
MyQ garage door loses connection daily to EX7700 extender
Hello, I recently rearranged my wifi setup and my smart garage door is closer to my extender (EX7700). My garage door loses connection multiple times a day sometimes for a few minutes and sometimes...
Sep 29, 2022Guru - Experienced User
Is it actually connecting to the extender?
reason I ask is the EX7700 is a mesh extender so it'll have the same ssid as the router (if you set it up that way).
And its (the MyQ) the device that decides if it connects to the router versus the extender when setup in mesh mode.
So it might be trying to connect to the router versus the extender and having issues.
You can disable the mesh mode on the ex7700 and give it its own SSID so the MyQ has to connect to it.
I'd try that and see if it stays stable.
