Timothyah2
Sep 29, 2022Guide
MyQ garage door loses connection daily to EX7700 extender
Hello, I recently rearranged my wifi setup and my smart garage door is closer to my extender (EX7700). My garage door loses connection multiple times a day sometimes for a few minutes and sometimes...
jamesbrown412
Mar 07, 2023Aspirant
Hi there! It sounds like the distance between your smart garage door and extender might be causing the connectivity issues. Here are a few things you could try:
Move the extender closer to the garage door to improve signal strength.
Consider getting a dedicated WiFi range extender or access point that is specifically designed for garage or outdoor use, as these devices typically have better range and durability.
Check if there are any obstructions between the extender and the garage door, such as walls, metal objects, or other devices that could be causing interference. Try moving these objects out of the way to improve signal quality.
Make sure that the firmware on your smart garage door and WiFi extender are up to date, as outdated firmware can sometimes cause connectivity issues.
Hopefully, these tips help you improve the connection between your smart Garage Door and extender.
- colleencamacho5Mar 13, 2023Aspirant
jamesbrown412 wrote:Hi there! It sounds like the distance between your smart garage door and extender might be causing the connectivity issues. Here are a few things you could try:
Hopefully, these tips help you improve the connection between your smart james smith online calculator and extender.
What firmware is on the CAX?
And on the EX7700?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
