BreedTN's avatar
BreedTN
Tutor
May 25, 2020
MYWIFIEXT isnt working
I cannot access the EX7500 via mywifiext.  Instead I jmusr aces it thru its IP 192.168.1.250.   Hardware Version: EX7500 Firmware Version: V1.0.0.52_1.0.68   How can I correct this?
  • schumaku's avatar
    May 25, 2020
    The special URLs are only workable while connected direct to the extender (WiFi, Ethernet port if any). Perfectly normal.
