Tcroome
Mar 24, 2020Aspirant
N300 Connected but not transmitting information
Hi all, Have been trying to figure this out throughout the day. I purchased the Extender and installed it as per instructions. All lights are green but the according to a WiFi speed test my co...
Mar 24, 2020Guru - Experienced User
did you set it up via wps or the installation wizard?
Not all device makers code wps the same and it can create issues. If you installed via wps, try resetting and installing via the installation wizard
Tcroome
Mar 25, 2020Aspirant
Thank you for the quick response! I used the WPS set-up method, but am unsure whether wizard would work as I have a Virgin UK Router, and not a Netgear Router?
I will give it a go though! Thank you!
