rupertx
Oct 24, 2011Follower
N300 dual band wont talk to Sitecom extender
Hi Folks
I have just upgraded from a DG 834 router to an N300 dual band ADSL2.
When I was using my 834 I had it connected wirelessly to a Sitecom 300n range extender which worked very well.
I have installed the new router and it is wired to my PC. All works fine.
However, I have tried to set up the Sitecom again to give me a stronger signal at the other end of the house but cannot get an internet connection with it.
My laptop etc all recognise and connect to the Sitecom but I get the message No internet connection.
It appears that the Router and Extender simply wont talk to each other.
Are there any settings in the Router setup which I should have changed to allow connection ?
Heres hoping someone can help
Thank you in advance
1 Reply
- jmizoguchiVirtuosoTry static ip in device side with ISP DNS used
