Charlotte123
Aug 27, 2020Aspirant
N300 EX2700 Connect with Web Browser Setup
Hello! I have a N300 Wifi Range Extender Model EX2700. I connected to the _EXT Wifi Network but when I launch a web browser and enter www.mywifiet.net I am told I am not connected to my extende...
Aug 27, 2020Guru - Experienced User
Try doing it this way.
connect a pc/laptop to the extenders ethernet port. Disable wifi on the device you connect to it. reason why is the ethernet port won't have a connection and the pc/laptop can default back to the wireless.
then try the mywifiext . net
Charlotte123
Aug 29, 2020Aspirant
Hi Plemans,
Thank you for your advice. I still get the message that I am not connected to my extender's WiFi network. I connected the router and extender through WPS. Could that be the problem?
Thanks again!
Charlotte
Thanks again!
Charlotte
- plemansAug 29, 2020Guru - Experienced User
It sure could be the wps. Try factory resetting the extender and reinstalling using the installation wizard and not wps.
