mervynsamson
May 16, 2017Follower
N300 EX2700 range extender
I tried to reconfigure the Netgear N300, EX2700 wifi extender. I pressed the factory reset button to add it into a new Windows network, but the old device name, ID/password and security information p...
DarrenM
May 18, 2017Sr. NETGEAR Moderator
Hello mervynsamson
You will need to hold the reset button down for 10 seconds to factory reset the unit. Then you should be able to set up the unit again.
DarrenM
