jhinkle17
Apr 17, 2021Aspirant
N300 ex2700
My extender worked with my old network (at&t uverse), I switched to Spectrum. Now I can't get the extender to connect to the wifi. I did a factory reset. When I try to connect via wps button, nothing ...
Apr 19, 2021Guru - Experienced User
what router are you connecting it to?
Try this.
Factory reset the extender. (push and hold reset for 7-15 seconds while its powered on)
Then hardwire a pc/laptop into the extender. Disable the wifi on the laptop/pc you connect to it.
Try setting it up using this method.
- jhinkle17Apr 28, 2021AspirantI cannot hard wire to my PC, my PC only has one ethernet connection, which goes to the router. I tried running ethernet from router to N300, I can connect my phone to N300, but there is no internet connection.
- plemansApr 28, 2021Guru - Experienced User
Your pc doesn't need to be online to setup the extender.
- jhinkle17Apr 29, 2021AspirantApparently, either I don't know what I'm doing(good chance), or this extender is bad. No matter what I've tried, it always wants an internet connection and there isn't one. Thanks for your time. This thing is going in the trash.
