Speedy1954
Mar 02, 2018Aspirant
N300 Extender has intermittent operation
Connected the extender within about 10' of wifi camera that had poor connectivity. 2.4Ghz network with a partition created for cameras. So we have: 1. networkrouter2.4G 2. networkrouter2.4G...
jvasanth1984
Mar 04, 2018Virtuoso
Hi Speedy1954,
Make sure extender is half way between your cameras and router. Also, try changing channel on router which can help you better. Do check for firmware upgrade for extender if any and see if your issue persist.
- Speedy1954Mar 05, 2018Aspirant
Ok will try moving the extender, how do I check for firmware upgrade? Is a dual band router, does the 2.4G go away when 5G is in use? Thx
- jvasanth1984Mar 06, 2018Virtuoso
Hi Speedy1954,
2.4GHz should not get disabled, but device can connect only to 2.4 or 5 at a time. Please use the below link for firmware upgrade.
https://kb.netgear.com/000053071/WN3000RPv2-Firmware-Version-1-0-0-56
