ejfreeman
Aug 06, 2018Tutor
N300 Extender
I have 2 questions:
1. How can I keep the extender from losing its internet connection? After an hour of no use in the extender, there is no internet .
2. Can I rename the extender the ...
DexterJB
Aug 07, 2018NETGEAR Moderator
Hi ejfreeman,
Welcome to the community!
1. What is the status of the Router Link LED?
2. Yes, you can rename it but it will be difficult to identify for troubleshooting purposes.
Dexter
Community Team
- DexterJBAug 12, 2018NETGEAR Moderator
Hi ejfreeman,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- ejfreemanAug 12, 2018TutorI reset it back to factory and it is working fine.
Thank you,
Ed - DexterJBAug 12, 2018NETGEAR Moderator
Hi ejfreeman,
Thank you for the update and confirmation. Glad to know you got it working.
Dexter
Community Team- jayburn84Aug 12, 2018Tutor
I have an N300 which I use to my secondary PC in my room (same room as the modem/router). I did not have an extra ethernet port available, plus considering how close it was I knew the signal would be solid heh. Besides a few hiccups when I initially set it up, then moved it, I have had 0 issues with the N300 going to one of my PC's. That PC just did not have a Wireless Card, I tried a USB WiFi Network Adapter, several, and they were all terrible. It was just easier to find a 1ft ethernet cable and patch into an N300 on the wall outlet in this room.
As for extending, I wasn't having much luck with that. The WiFi signal off the N300 _EXT network given was not very good.. but that was when I had it downstairs trying it for a laptop. I think these things are really only good for apartments, or to be in the same or next room to your modem/router. I'm not convinced they extend all that far, but they are great to keep close by if you have a PC or device and don't mind running a short network cable.
