Baranlyle
Jan 27, 2020Follower
N300 Model EX2700 I can't setup
Can someone please help an IT NOT!! geek! My dad bought a N300 wifi range extender, it tells me to connect to my 'router'. I have a sky Q box which I get my wifi on, is this what's called a Router?...
Jan 28, 2020Guru - Experienced User
Baranlyle wrote:Can someone please help an IT NOT!! geek! My dad bought a N300 wifi range extender, it tells me to connect to my 'router'. I have a sky Q box which I get my wifi on, is this what's called a Router?
Please help, thank you. My Dad's daughter, Claire :)
yes the sky Q box that you get your wifi on is the router.
I'd highly recommend a look at the support site if you're not a geek :).
It has walk through video's of setup using both WPS and the smart connection wizard, written guides, a manual, firmware, and troubleshooting.
https://www.netgear.com/support/product/EX2700.aspx
