Mutsey
Feb 12, 2025Aspirant
N300 Range extended limited speed
Hi everyone, I recently setup the N300 Wifi Range extender. Connection is very good between the extender and my Wifi Router. I have the N300 plugged into a Netgear 1 GB 5 port hub and my other device...
Mutsey
After researching it appears it's the WPA2 security that's limiting the speed. I do not see where the N300 will let you change the WPA security. Looked through the Manual and online and there's no Security Settings option on the N300 settings page.
