Mutsey
Feb 12, 2025Aspirant
N300 Range extended limited speed
Hi everyone, I recently setup the N300 Wifi Range extender. Connection is very good between the extender and my Wifi Router. I have the N300 plugged into a Netgear 1 GB 5 port hub and my other device...
Feb 12, 2025Guru - Experienced User
If the extender is extending the host wifi signal, the extender just passes on the security mode set by the host router.
