Mutsey
Feb 12, 2025Aspirant
N300 Range extended limited speed
Hi everyone, I recently setup the N300 Wifi Range extender. Connection is very good between the extender and my Wifi Router. I have the N300 plugged into a Netgear 1 GB 5 port hub and my other device...
Feb 12, 2025Guru - Experienced User
N300 extenders are extremely slow (and old tech). that 20-30mbps is about all you're going to get from one over wifi.
If you're wanting/needing faster speeds, you'd need to upgrade.
What speeds do you pay for?
What speeds do you want/need from the extender?
- MutseyFeb 12, 2025Aspirant
Appreciate the reply. Yes after spending all morning with it, way too much time, I finally ordered a new TP Link AC1900. The comments online suggest that you have to adjust the WPA2 security setting and says you can find it under the Wifi Settings on the N300 landing page. Nope, it does not exist!
- FURRYe38Feb 12, 2025Guru - Experienced User
That probably only applies if the N300 was in AP mode. Extender mode has to follow what is set on the host router.
