Michaelfob1
May 06, 2020Aspirant
N300 range extender
The device connects with both WPS and through Netgear instillation app. However shows NO INTERNET when connecting to any device. I am guessing security settings on my home WiFi hub need adjusti...
- May 06, 2020
have you taken a look at virgins site?
Eatonsmith
Have same problem however initially worked OK and now has just stopped and won't reset (had it 5 weeks). Using the online system means you end up in a virtual loop with no progress... on the phone to support now and will let you know if have any success
- Michaelfob1May 06, 2020Aspirant
Ok good luck
- plemansMay 06, 2020Guru - Experienced User
What router are you connecting to?
What firmware is on the extender?
It’s a virgin media hub 3.0
Im trying to connect to an iphone, iPad and also a smart tv.
