appple1
Aug 20, 2011Aspirant
N300 router (can't login router)
I had my N300 router set as repeater to extend the range of Wifi in our house, the main router is RangeMax Dual Band 3300, They are working fine. The wireless channel was set at 11, now I would like ...
Daedalus01
Aug 21, 2011Aspirant
If you have 2 devices, they both have to have separate ip address. ie. 192.168.1.1 and 192.168.1.2 that way you can have access to both devices. From the sound of it, the n300 might not be setup correctly.
