appple1
Aug 20, 2011Aspirant
N300 router (can't login router)
I had my N300 router set as repeater to extend the range of Wifi in our house, the main router is RangeMax Dual Band 3300, They are working fine. The wireless channel was set at 11, now I would like ...
jmizoguchi
Mar 25, 2012Virtuoso
link is NOT repeating
repeating when BOTH router/AP are connected wireless each other which are NOT same as the URL given. URL are connected PHYSICALLY with CAT5 between the two devices
if both are setup SAME as URL given then you can use same SSID for same family router or simply just want two location with different SSID then you can do that as well.
