Razim's avatar
Razim
Follower
Jun 02, 2019
N300 Wifi extender
Hello
Can anyone help me in how to connect a 2nd range extender to my wifi
when i try to install it i log in via mywifiext.net, it asks for my username and password which i enter (as I already have installed one range extender a few months ago) and thereafter i cant see any option to install a 2nd device, can someone please help
thanks
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Razim,
    Factory reset the extender by pressing on the small black button using a pin for 15+ seconds and join the NETGEAR_EXT wifi network.  After you connect to it, browse to www.mywifiext.net and follow the setup instructions. I would recommend that both extenders are connecting to the router and not each other.
    ~Christian
