MarcusReynolds
May 24, 2020Follower
N300 WiFi Range Extender EX2700
Hi, I have just changed my broadband from Sky to Vodafone and have a new Router. The Router is connected to my Netgear N300 range extender and I can connect my PC to the _EXT WiFi via WPS on the ext...
May 24, 2020Guru - Experienced User
The way wps works is it should copy the password from the router.
Problem is that wps isn't always coded the same.
If you setup using wps and some devices aren't working, factory reset the extender and install it using the installation wizard instead of wps.
