hooper62
Jun 01, 2020Tutor
N300 WiFi Range Extender Model EX2700 Doesn't Connect
My N300 range extender has worked fine for a number of months, but for some reason now it has stopped. Tried factory resets a few times and it appears to link fine via WPS to the wifi router (all lig...
Jun 01, 2020Guru - Experienced User
Try factory resetting and reinstalling it using the smart installation wizard and not using wps.
wps gets coded differently between device makers and can cause issues because of this.
