hooper62
Jun 01, 2020Tutor
N300 WiFi Range Extender Model EX2700 Doesn't Connect
My N300 range extender has worked fine for a number of months, but for some reason now it has stopped. Tried factory resets a few times and it appears to link fine via WPS to the wifi router (all lig...
Jun 02, 2020Guru - Experienced User
have you tried connecting a pc/laptop to the ethernet port and setting it up hardwired? just make sure to disable the wireless in the device you connect so the connection doesn't default back to the wireless
hooper62
Jun 02, 2020Tutor
Tried the wizard this morning and this time it worked - no idea why. All working fine now!! Thanks for your help.
