AzureFox
Apr 07, 2020Follower
N300 Wifi Range Extender not working after update
Hello! I was trying to reset my wifi extender to connect it to a different network on the extender settings link provided with the product. I hadn't been on it since I got the extension last year in p...
Hazhir
Apr 16, 2020Aspirant
I have the same issue and I tried to factory reset but it doesn’t work at all
Power LED Keeps turning on and off
Please someone help
Please someone help
Hotrod1969
Sep 16, 2020Aspirant
Exactly the same issue here. Just updated the unit. It was working perfectly before, now no signal and blinking power light. Tried factory reset, made no difference. Any answers from NetGear ??
- plemansSep 16, 2020Guru - Experienced User
this is the community forum, you won't see much from netgear on here.
a blinking power light tends to indicate corrupt firmware.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
If that doesnt' fix it, start your own thread so we can better assist you instead of jumping on another thread.
