JP1950
Dec 23, 2015Initiate
N300 WiFi Range Extender password
My Ipad is usually connected to my Extender. But in the last few days it is asking for a password when I try to connect to the Extender. I set up a password when I first installed my Extender but I c...
- Dec 23, 2015
Don't think there is a way to retrieve it. Just factory reset it and start again with the set-up process
Hope this helps
clithes
Dec 23, 2015Prodigy
Hope this helps
JP1950
Thanks for advice. I did factory reset and re-installed extender by following instruction bookletPages 6 and 7. Password of router was needed. Worked properly.
