MikeTitusville
Nov 25, 2020Follower
N300 WiFi Range Extender security
My devices show good security when connected to wireless router, but "weak security" (WPA/WPA2 TKIP) when connected to the range finder. How do I get range finder to better security? Thanks
Nov 25, 2020Guru - Experienced User
The range extender doesn't "find" better security. You actually log into it and set the security up through its settings. The manual goes over doing so.
Here's where you can find the manual
