Nakkatja's avatar
Nakkatja
N300 Wifi Range Extender wrong password problem
Hi! I have just bought a wifi extender. But when I enter my password it says it is the wrong password. But it’s the right one (the same as the wifi router). I dont know what to do.. Does somebody know what is wrong?
Thank you in advance :)
  • plemans's avatar
    Need more info.
    how are you accessing the extender? netgear genie, netgear app, browser gui?
    are you accessing it over wifi or ethernet?
    Are you using a password manager or have you tried manually typing them in?
    the password for the router might not be the same as the one for the extender.
    have you tried the default info? login admin password is password
    • Nakkatja's avatar
      Nakkatja
      I’m trying to access the extender settings but it says I cant connect to the extender, I’m going to this site Mywifiext.net on my laptop, I connected the extender to the main router and the lights are on
      • plemans's avatar
        1. Model number:
        2. Has it successfully been setup? you say the lights are on but did you go through the full setup procedure. And if the lights are on, how are they lit. colors, blinking etc.
        3. You say you can't access it. do you mean you can't log into its wifi or you can't access it once its connected to your router?
        4. Are you sure its connected to your router? If you go into your attached devices page on your router, does it show up on your attached devices list?  If it shows up on your attached devices list, it'll have an IP address. Can you access it from that ip address?
