PatCol63
Jan 24, 2018Aspirant
N300 (WN3000RPv3) WiFi Range Extender Client link keeps dropping
Hi I have a N300 range extender (WN3000RPv3) which I bought a couple of years ago and used successfully pretty much without interruption. On 15 January I changed broadband provider which also meant a ...
PatCol63
Jan 31, 2018Aspirant
Thanks for your reply. The link between my router and extender is solid; it's the client end of the extender which is prone to drop. would changing the router channel have any effect on that?
DarrenM
Feb 02, 2018Sr. NETGEAR Moderator
Yes as the extender would be using that channel as well to broadcast the the clients.
DarrenM
