MXHowes
Oct 31, 2016Aspirant
N600 WNDR3400V3 need to extend WiFi to guest house 200' away by wire.
N600 WNDR3400V3 need to extend WiFi to guest house 200' away by wire. I will be running an ethernet cable from my house to the cottage. The place is only 320sf and getting the WiFi connection to Exed...
DarrenM
Nov 02, 2016Sr. NETGEAR Moderator
Hello Mxhowes
You may want to look at the Ex6200 or ex7000.
DarrenM
MXHowes
Nov 02, 2016Aspirant
Thanks for the info..... I looked at the Ex6200 manual and it looks like I can set it up as an access point in my guest house via Ethernet cable and be able to use it for WiFi only (the Ethernet ports will not work). This will work for me, Thanks again
