Commuter63
Jun 01, 2020Aspirant
N900 - Can't connect using ethernet or wifi
I've recently changed ISP and have decent new router and an old n900 I wanted to use it as an access point to improve the wifi upstairs. I have tried connecting to it via ethernet and wifi using a wi...
Jun 02, 2020Guru - Experienced User
Which router is it? N900 is a speed, not a model.
you can go to netgear.com/support/ type in the model number that you have. Then look for access point mode.
in the manual, look for access point mode
- Commuter63Jun 02, 2020Aspirant
Does that matter when I can't even connect to it?
- plemansJun 02, 2020Guru - Experienced User
It does matter. What are the led's on it doing?
All of them. color/blinking/solid/etc.
The following lights are on and solid
wifi
power
2.4ghz
5ghz
