Commuter63
Jun 01, 2020Aspirant
N900 - Can't connect using ethernet or wifi
I've recently changed ISP and have decent new router and an old n900 I wanted to use it as an access point to improve the wifi upstairs. I have tried connecting to it via ethernet and wifi using a wi...
Jun 02, 2020Guru - Experienced User
Which router is it? N900 is a speed, not a model.
you can go to netgear.com/support/ type in the model number that you have. Then look for access point mode.
Commuter63
Jun 02, 2020Aspirant
Sorry. Its a WNDR4500v2 but it won't connect via ethernet, doesnt show up as an option when scanning wifi and doesn't respond via browser to either ip (192.168.0.1) or routerlogin.net. I've tried various lan cables including brand new
I'm not sure what to try next. Any help appreciated
