Michaelknox99
Aug 01, 2018Follower
Neatgear wifi extender suddenly becoming slow
Model EX2700 – N300 WiFi Range Extender Essentials Edition Ive had this for nearly 2 years now it is great gave me a very good signal in my room which never used to have good connection otherwise. ...
DexterJB
Aug 06, 2018NETGEAR Moderator
Hi Michaelknox99,
Welcome to the community!
1. What is the firmware version of the extender?
2. What is the status of the Router Link LED and does it change when the disconnect happens?
3. Does the issue persist on all the devices that connect to the extended network?
4. Do you have a device wired to the extender?
Dexter
Community Team
- DexterJBAug 12, 2018NETGEAR Moderator
Hi Michaelknox99,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
