pthang
Jul 21, 2020Aspirant
need advice on best modem/router to go with EX8000
i recently purchased a land line phone to finally start using the landline that comes with my cable package for my business line, and realized the netgear modem/router combo i have doesnt have the ab...
- Jul 22, 2020
pthang wrote:woof, looks like im going to be out around $600-$700 to get 1gbps+ speeds when i already have a router/modem that gives me close to those speeds.
top of the line equipment is expensive. sorry.
You don't have to buy the best router as you can upgrade that as needed. You can also checkout amazon's renewed routers. They've had the orbi setups on there for pretty reasonable priced and the orbi's have been great (the triband ones).
I would recommend buying a solid modem though as its the backbone of the whole system. plus you're kind of stuck because you want voice with it. There aren't that many voice modem's that support gigabit and voice. That's kind of what hits the wallet. without the voice, you can find them for almost half the price.
pthang
Jul 22, 2020Aspirant
pthang
Do you happen to have a router you would also suggest with this modem? everything i check online has very mixed reviews.
