Retired_Member
Jun 01, 2020need advice on wifi range extenders
Hi please help, all sugestions will be a big help, tried tech support but no feedback from them, i just purchased a very small motel,i have high speed internet thru media com , i need some help,,t...
Jun 02, 2020Guru - Experienced User
I would look at the orbi pro setup.
This would allow business class functions as well as the ability to expand the system for added coverage if you needed it.
Retired_Member
Jun 02, 2020Hi
Thanks Tons
Tom
