Bassett72
Sep 24, 2019Aspirant
Need better wifi coverage
OK, I have a TRI-LEVEL home. For many reasons, I would love to change that, but it just isn't in the cards. When I say TRI-LEVEL, there are actually 4 levels. A basement (concrete walls and where ...
- Sep 27, 2019It works the best imo with a wired backhaul
Bassett72
Sep 27, 2019Aspirant
Thanks, for the help as I was leaning towards teh RBK53, I think that is the route I'm going to go. It will be overkill, but that is OK with me. Hopefully I can get some decent coin for my 3 month old R9000 and EX8000 parts. Guess I'll try the Orbi first, the go to Ebay..
ONE last question...Hopefully....If I can Hardwire the satelites (run an etheret cable from my network switch to the satellite) does that help? Or does that even work?
Sep 27, 2019Guru - Experienced User
