rarewolf
Dec 15, 2015Aspirant
Need hard connection upstairs ... EX2700 or WN3000?
I need to provide a hard connection to the WAN and my LAN for computers and NASs (upstairs) to the primary wifi router (downstairs). I had this working at one time with a Asus router configured as a ...
- Dec 26, 2015
Just thought I'd close this topic out with having solved this. Amazon.ca offered the EX2700 on sale for less than $25 (CAD!), so I figured I had little to lose by buying/trying it in place of the TPlink. All that was needed was the quick setup, and the configuration allowed for upstairs hardware obtaining the 192.168.2.x subnet that I needed. All is working great and the signal strength through the floor was 95%. I'm good!!
Holidays' Cheers!!
TheEther
Dec 16, 2015Guru
I dunno about the range. All of the reviews I've read say that it's not good, like 30 feet. It's meant to be used in a single room environment, not necessarily across floors.
I suggest that you try to get client mode working in the same room as the primary router. Then move it to the other floor.
