Rugae
Apr 26, 2020Aspirant
Need help connecting to 5GHz on the EX7500 Wifi Extender
Hello, I have a problem connecting to the 5 GHz with the EX7500 Wifi Extender. On mywifiext, it indicates that the extender is connected to my router. My router is Netgear RAX40. However, under 5 GH...
Apr 27, 2020Guru - Experienced User
the EX7500 is a triband extender. so you have 1x 2.4ghz radio and 2x 5ghz radios. so one is connected to the router (which is showing). the other is for devices to connect to. If a device is connected to the 5ghz, the 5ghz led will light up. If nothings connected to it, it stays off. Your status page you linked it showing 5ghz broadcasting with nothing connected to it. So the lights off.
If you're using the "onessid" function, it bandsteers devices between 2.4ghz and 5ghz. your devices must be on the 2.4ghz.
- RugaeApr 27, 2020AspirantThank you for your response.
The thing is I have multiple devices connected to 5 GHz but the light is still off, though I can still use the internet on these devices. The light is not broken because when factory reset the extender, all the lights showed up normally. Not sure what the problem is.- plemansApr 27, 2020Guru - Experienced User
so you're using it in mesh mode? using the single ssid function?
Are you sure they're not connected to the routers 5ghz?
They don't show up in the connected devices page? for the extender
- RugaeApr 27, 2020AspirantHi there,
The router is connected to the extender for both 2.4 and 5 GHz. If you look at the picture I posted along the first post, you can see that from router to extender, the color shown is green so they are connected. However on the extender side, under 5 GHz, it says “No connection” while the 2.4 GHz is connected as normally.
L
