Rugae
Apr 26, 2020Aspirant
Need help connecting to 5GHz on the EX7500 Wifi Extender
Hello, I have a problem connecting to the 5 GHz with the EX7500 Wifi Extender. On mywifiext, it indicates that the extender is connected to my router. My router is Netgear RAX40. However, under 5 GH...
Rugae
May 06, 2020Aspirant
Thank you for your response.
The thing is the extender is currently in the same room as the router and is about 10 steps apart. The reason I’m doing that because I’m running into all these troubles and I want to eliminate distance as a factor :(. Do you think this has something to do with the channels they’re connecting to? Router is connected to channel 7 for 2.4Ghz and channel 118 for 5GHz. Extender is defaulted at “Auto” for 2.4 GHz (can’t change to anything else) and channel 149 for 5GHz
May 06, 2020Guru - Experienced User
the extender backhaul functions off the routers 5ghz.
Try changing your routers channel to a lower channel range (36-48) and not the DFS channels.
Then reboot the router and extender and see if the 5ghz willl connect.
If it doesn't, rerun setup on the extender. The whole purpose of the tri-bands is that 5ghz backhaul so speeds are faster because 2.4ghz is slow.
