bigtruck1996
Dec 16, 2018Aspirant
Need help extending and boosting wifi signal
I know this subject has been covered before but I can't quite piece it all together. I just changed my ISP to Century Link. The modem/Router had to be located in a different place than my old route...
- Dec 17, 2018
bigtruck1996 wrote:
I could not find the model numbers that you gave me.
They are here: https://www.netgear.com/home/products/networking/wifi-range-extenders/default.aspx
bigtruck1996 wrote:
However, would the line of mesh extenders work? In particular the Night Hawk X6S the desk top model?
Note that the X6S extender's model number is EX8000.
The EX7500 is one of the mesh extenders. It happens to be a plug-in module, instead of free-standing (as the EX8000 is). However, the EX8000 would of course also work.
bigtruck1996 wrote:
Also, do these extenders require an ethernet/coax or do they connect with my current router over the wifi bands?
Extenders (by definition) can connect to your router over wifi. Most (including Netgear's) also have the option of connecting with ethernet.
bigtruck1996
The router that I have is an Actiontec C3000a. I am getting a good signal in the breeze way. This is where I do all my computer/internet work and I have not had any problems getting and keeping a wifi signal.
Dec 16, 2018Guru - Experienced User
It sounds like a plug-in extender in the breezeway would work.
The EX6110 is one option, though an EX7500 would perform better (though is more expensive).
