rpollard's avatar
rpollard
Need help selecting wifi extenders that work with limited connections -wifi hotspots
I am forced to rely on a cellular (AT&T) phone as my only form of internet connection due to the location where I live.  Believe it or not, it works pretty good with download speeds around 23-30 meg on a good day and uploads around 5-10 meg.   The problem is the device (I-Phone SE) has limited wifi range, and only supports 8 connections.
I need an extender, or mesh, that will extend the range in a single-story wood farmed home, approximately 2200 square feet.   Is thre a technology that i can use that will not consume a connection for each extender?    Currently am using an older AC1200 ex 6150 extender, which consumes a connection and is not very powerful it seems
Any advice is much appreciated!
Bob
    • rpollard's avatar
      rpollard
      The phone I am using came as part of a package plan with AT&T called FirstNet.   (I am a first repsonder).
      Would a device such as the one you are reccomending work with the SIM card from my AT&T Firstnet phone & service?
      Thanks for your advice.  I am a firefighter, not a wifi guru!!!
      Bob
      • plemans's avatar
        Bob
        You'd need to check with att if it'd work in a hotspot and not the phone. Theoretically it should. I've swapped the sim in my phone to a hotspot before but I'm not sure what/if att has changed since I've been with them (att).
