Microfiche
Jan 19, 2021Aspirant
Need help with extending range
I seem to be unable to use a mesh system as I want to use Yamaha MusicCast and I have 2 receivers that need to be on the same network in order to work properly, but the odler one will only connect to...
- Jan 21, 2021
In the event anyone ever searches for MusicCast and mesh Wi-Fi here, I will answer my own question.
I gave up waiting for Yamaha to get back to me, and I didn't get much help from various forums, as I went ahead and set up the Linksys WRT1900ACS in wired bridge mode upstairs, connected to the Nighthawk AC2100 Smart WiFi Router through a switch and disable the 2.4 GHz network on the LInksys. That pretty much solved all my problems, except for the money I spent on the Netgear MK62 system that would not work. My phone even controls the MusicCast equipment when connected to the new 5 GHz network, so the problem must be that Yamaha MusicCast wants all the controlled equipment connected to the 2.4 GHz (or same - but I can't test that as the older unit can't connect to 5 GHz) network. What a pain.
Microfiche
Jan 21, 2021Aspirant
