Anonymous_User
Jan 31, 2018Follower
Need Help With Extending Wifi with Ethernet Option
I have a NETGEAR R6200 wireless router and I want to connect a LINKSYS SPA1001 Analog Adater to a room. The adapter requires an ethernet cord and the room is way too far to run an ethernet cable to it. I was thinking of getting a NETGEAR AC1200 WiFi Range Extender - Essentials Edition (EX6120-100NAS) as it has an ethernet port for attaching the Adaptor. Do you think this will work and if not can you give some advice on a better way of going about this? Any assistance in this matter would be greatly appreciated.
Sincerely,
Anonymous User
1 Reply
- DarrenMSr. NETGEAR Moderator
Yes this should work but remember that you can lose up to half your internet speed when using a extender so as long as you can get that min amount of speed needed for that linksys device you will be fine.
DarrenM
