Cissie
Jul 02, 2018Follower
Need info on extender or wireless router to bridge with AT&T- Model 5268AC modem/router
Hello, I have a AT&T PACE ARRIS Model 5268AC as my WiFi Modem/Router (we have fiber optic) , I want to add a couple of Range Extenders or wireless routers for online TV streaming. My problem is "comp...
DexterJB
Jul 03, 2018NETGEAR Moderator
Hi Cissie,
Welcome to the community!
The device that you have is already a modem-router combo, so you will most likely no longer need another wireless router since that will only complicate things unless you want to setup an entirely separate network and/or prefer the flexibility of a router that can be configured as an access point only. A regular extender should do just fine with what you have described. This allows your devices to be under the same network and may save you on cost.
Here is the link for the NETGEAR extenders.
Dexter
Community Team
