BP97756
Aug 28, 2023Follower
Need more powerful Mesh than my EX6400V3 to reach out 500 yards
My AC1900/EX6400V3 mesh extender works fine to reach the ring devices on my unattached garage about 30 feet from our house, but the signal at my new shop about 500yards away is to weak for my Ring ca...
Aug 29, 2023Guru - Experienced User
There isn't for extenders. that's too far to reach.
You could use a point-to-point system to get a hardwired connection there and then connect an extender/access point/router to it.
netgear has airbridge for point-to-point systems but its been out of stock for a while so you might need to check with a different vendor.
