Nancywb70
Sep 01, 2020Aspirant
Need recommendation for new WiFi extender
Hi - We need to upgrade our WiFi extender. We currently have the WN300 RP but it is not working well with our ADT cameras which seem to be falling out of range. We have an Orbi RBR50. Which WiFi e...
Sep 01, 2020Guru - Experienced User
If you've already got an orbi router (and the rbr50 is a solid one at that) I'd add satellites to it.
You can use the RBR20, RBW30, RBS40, RBS40V, RBS50, RBS50Y.
the EX7500, EX7700, EX8000 would all also work but wouldn't be "controlled" by the orbi router like the full orbi satellites.
Nancywb70
Sorry. I think the extender is for our ADT system wich is an Arris Touchstone CM8200. That is what we need the extender for.
- plemansSep 01, 2020Guru - Experienced User
the Touchstone cm8200 is a modem only. What router do you have?
- Nancywb70Sep 01, 2020Aspirant
We have the Orbi router for our home wifi. The Arris is supplied by ADT and only for our 3 security cams. One camera keeps dropping because its too far away. I think we need the extender for the cameras. Its confusing. The Netgear WN3000RPH extender we have now works, but the red light keeps coming on and our one camera keeps dropping. I'm thinking we need a stronger one. Not sure which one to buy.
Thanks for your help!
If you truly have the arris cm8200, its a modem only. it doesn't have routing, it doesn't have wifi.
Whoever setup the WN3000rph, more than likely connected it to your orbi setup. It could be part of the issue.
You acn always log into your extender and check what signal its connected to.
